engine block crack
starcraft 66
does sommeone know were i can buy a engine block only cheep because mine crack below the intake and i want to re-sold the boat i rebuilt in 90 % the boat and i dont what to lose the money i put on it
Re: engine block crack
Ayuh,.... What motor,..?? Vintage,..??
OK - next question is where are you located and how far are you willing to travel for a block?
starcraft 66
im in gatineau quebec 2 hour from montreal to answer your question all depend how much they sale the block
Sorry we cannot help you, as the distance between us would not make for a reasonable trip. We might suggest that you look around for an older vessel sitting with a 120. There are a great deal of the 120s still around and many are still very solid engines. Much like where you have a strong hull and a bad block, others have vessels with weak hulls or transom and folks just park them. Often they will let them go for next to nothing just to get rid of them.
starcraft 66
thank for your help and if i dont find another one ill try tofix it because the crack is where the water chamber below the manifold thank
