trim switch?
tony6813
my tracker boat has a trim tilt switch in the throttle lever,up on the side of the hull I need a new one and cant find just the switch. they all com with the whole handle assy. can anyone help me get back on the water?
dwco5051
Re: trim switch?
Had the same problem a year ago. Took the handle apart and sprayed the inside of the switch with contact cleaner and woked the switch back and forth for about 10 minutes and it started working. It is still working this year. Made a mental note to try and locate one but never got around to it.
tashasdaddy
Re: trim switch?
suggest you post in the manufacturers forum. we have no idea what you have.
