scottmach1
Thread starter- Joined
- Oct 3, 2009
- 3
What year is this model, s/n?
18602C-E12819
I recently retrieved it from the bottom of the lake a week after it went down while running
, (long story).
I immediately pulled the plugs and oiled up the cylinders and anything else I could, carb, linkage etc.
I got it running (with a double oil mix) and it seems to run fine, but I don't think the water pump is working because the shaft gets awfully hot after a few minutes of running. I think the water's supposed to exit out the exhaust port up high on the shaft and there doesn't seem to be much if anything in the way of water coming out of it, just exhaust. Is that where the water should pump out on this outboard?
Thanks.
18602C-E12819
Thanks.
