tilt/trim help 89 Evinrude 50hp
rickeyi
I need help learning about the tilt and trim on my 50hp Evinrude, completely new to me but am mechanicly inclined to learn.
Can someone tell me how to drian the fluid out of my tilt and trim, then how to properly fill it.
Captmills
Re: tilt/trim help 89 Evinrude 50hp
do a search on tilt and trim. There is a ton of info already on this site
rickeyi
why even reply if that's all you have to say
Daviet
If you plan to maintain your own engine you might want to get a factory manual, it will ansewer a lot of questions. The manual will also have a trouble shooting section for future problems.
rickeyi
Have 1 ordered just thought could get some help before I received it, instead of the wasted replies
Daviet
Why should we waste our time trying to reinvent the wheel when you are to lazy to try and help yourself by researching your problem. There is a ton of information that has been discussed in previous posts, as suggested, try a search.
rickeyi
why even waste your time even posting you idiot. I have researched it and the ones I've found that are discussed is different than what I have and you cant just run that motor up and still get to the fill resvior smarta... so just take your fat a... some where else
