NatureDriven
Thread starter- Joined
- Sep 5, 2009
- 2
Hi all,
New to the forum here, after reading many posts, it looks like there are some pretty knowledgeable folks on here, hopin' I can get some good advise.
I recently purchased a Honda B75 4-stroke that hasn't been started for at least a couple years. Prior to it sitting, the motor would start up, idle and run with no problems on the first or second pull. I'm not sure of the year, the motor reads "B75-1005709". When I brought the motor home I immediately drained and changed the oil with 4-stroke marine grade 10w-30 oil. Also checked the plugs, and they are good. I've been able to get her started and revved up to the max with the choke pulled out half way; however, after I let her run like this for a few minutes then slowly start to wind her down to idling speed she dies out. Also, it pee's a steady stream of water.
Anyone have any idea's of what could be causing this?
