Azonic
Thread starter- Joined
- Aug 18, 2009
- 279
Re: Starcraft Mariner V to shallow/narrow for a center console?
So, charging system...
Found a few hate sites for "Split Charge Relay" systems...
Found a few hate sites for "Split Charge Diode" sytems...
And I am not going to spend alot of money on the "Split Charge Mosfet" systems...
I found this diagram for a "Split Charge Relay" system that was fused.
I felt it solved the significant short comings of the relay system...
I wanted to simplify the charging process also, and decided to use the existing relay. Most relays have dual "#86" pins.
Make one pin the charging system as normal...
use the other pin to activate the relay when you plug in your battery charger.
This will allow for dual charging and keep the systems seperate.
I think the recomended 30amp fuse is good for charging.
(my battery charger only hits 6amp anyway)
and the motor charging system can do more, but this allows fora controlled flow, and protects the system from blowing the relay or either charging system...
Thoughts?
Thoughts?
