Re: what is normal operating temperature 5.7 volvo?
I have a 95 5.7L Merc..and I run around the same temp as you..doesn't matter, slow speed, high speed..idle..stay nice and cool. It runs fantastic as well, so I'm wondering if we should just leave it alone?? Or are there cons to this?
The role of the thermostat is to warm the engine to peak operating temperature and keep it there. Cons of running cold include:
- Increased fuel consumption and emissions
- fouled plugs
- Cylinder wall scoring from unburnt fuel "washing" lubricant from the cylinder walls.
- Carbon buildup on pistons and valves
- Improper lubrication from oil not thinning properly
All of these decrease engine life expectancy. If yours doesn't have a thermostat, there's a chance that the PO removed it because it was running hot from some other issue, and that issue is now being "masked"
Set the engine up the way it's supposed to be.
