4.3 volvo flywheel thickness?
Dave-R
Hello all : I am replacing a 1996 Volvo 4.3 engine with a brand new marine engine. I did need the old flywheel from the old engine. The new engine is about 1/8" longer where the flywheel mounts than the old motor. When I put the flywheel, and the coulper together, the coupler hits the crank before making contact with the flywheel leaving it loose. Anyone ever see this trouble before. Also could I take it to a G.M. dealer and use a truck replacement. Not sure what to do ,any help will be appreciated.
Thanks Dave
Dave-R
Re: 4.3 volvo flywheel thickness?
I have found a few places that sell flywheel shims. I will have to place these between the flywheel and the coupler. Not to happy , but maybe this is a standard procedure. If I put the shims behind the flywheel I, think I would have starter alignment issues. Dave
Ayuh,... I don't know just What you've got going on,...
But,..
I Do know the flywheel shouldn't have to be Shimmed...
A standard flywheel from a truck is the same as those on boats...
ENSIGN
I had the exact same problem at the shop last year,the dimensions of the crank are different, had to get a flywheel for that year block.
zbnutcase
And starter will need changed, the noses are different too. 'nutcase
Fun Times
I don't know just What you've got going on either but, Keep this in mind I have seen a thread some place eles that on merc engines they have a few styles of engine couplers out, And some one installed the wrong style coupler and the shaft from the sterndrive some how became to long and was pushed into the engine crank and it damaged the crank area:eek: I'm not saying this is the same thing, But be carefull with this one is all.;)
I went and copyed and pasted what he and some other guy's have found in the past and done to try and fix it if anyone is interested in reading it, Just as a FYI thing to look out for in the future is all. Also Dave-R as i read this more I don't think this will happen to you, But again becarefull.
FYI Bravo1 HP Coupler
You to can lose a motor if you don?t follow this. The HP coupler it will put pressure on the crank thrush bearing when under a load.
Talked to merc racing this morning the HP coupler that was sold to me was not right for my application. The shaft on my unit has a longer taper with 2 o-rings on it which makes it stronger. The shaft for the HP coupler taper is shorter with 3 o-rings. Merc says to either change shaft or have mine turn down. I told them that if I did that it would weaken the shaft either way but this was their fix. So I am going to turn down the coupler end down 1/2? instead.
What I am finding in my case is the spline is bottoming out before the nose of yoke shaft hits the back plug on the coupler. Even if the plug was not there it would not go any further...Then next interference would be the taper on the shaft if I could get it to go deeper. I have the 9 1/2" two o-ring shaft. My question is on the three o-ring shaft is the spline them self longer than 3" or 3.250 from the nose of the shaft to the end of the spline. If the spline is more than 3.5? long from the nose with the plug knock out and turn around this would give it 0.250" more clearance and correct the problem then.
Been there. Done that. I used the coupler with my long shaft and didn't realize that when I tightened the drive the shaft pushed the coupler forward which in turn had the crank thrust surface bound tight against the rear main cap & journal. One new crank later and a rebuild I machined 1/2 inch out of the rear of the coupler.
I found out when I was removing the drive. It would not come out with any amount of prying. Had to cut the input shaft on the inside of the transom with a sawzall, then pull the drive. Engine had to come out, took off the coupler and had to beat the remaining splined piece of input shaft out of the coupler. Once done, thought no big deal, replace the input shaft. I had my motor hanging on the hoist. Went to reposition the motor so I pulled on the crank pulleys. The pulleys and crank moved about 3/16th of an inch forward first then everything else followed. It should be .070 thous max. Upon teardown, found the crank thrust surface completely destroyed. At that point I just replaced everything in the motor with new. Bear in mind that my transom thickness is 2 1/2 inches thick instead of the recommended 2 - 2 1/4 inch which pushed my drive back even further from the coupler. I guess if I had standard transom thickness I would have noticed this problem when installing the drive as it would of bound up tight before the drive pulled all the way in. Oh well, expensive lesson learned.
I got a call from a customer in a panic last night regarding this issue so I figured we would take some measurements. We measured from the part of the U joint yoke that sits against the gimbal bearing to the rear of the coupler (which would be the flywheel).
There is a difference of up to .278. The point of interference is the spline on the long couplers/old shaft , the new style shaft is the same length but more spline. On the short couplers the shaft runs into the plug that closes off the spline cavity.
The new 3 o ring shaft is used after serial 0M10000, roughly 2000 model year.
What we don?t know is the dimension from the bearing to the flywheel on an installed engine. Anyone want to measure?
Attached ThumbnailsI got a call from a customer in a panic last night regarding this issue so I figured we would take some measurements. We measured from the part of the U joint yoke that sits against the gimbal bearing to the rear of the coupler (which would be the flywheel).
