Choke Plate Closing & Carb Dumping Fuel (leaky carb float)
myoldboat2
1974 Mercruiser 140 s/n 388xxxx
Mercruiser "Late Model I" Stern Drive s/n 390xxxx
Rochester 2-barrel carb with choke with heat tube from rocker cover
Summary: Choke works right until engine fully warm, then choke plate ends up tightly closed with a lot of tension on the choke coil.
Details:
Had my engine out and back in to replace coupler. Used carb cleaner to clean up the linkages but otherwise didn't touch the carb. Changed starter and plugs while engine was out. Back together and tested fine on muffs.
As usual started great cold with three pumps and cracking the throttle. Warm it up and go--ran great. After about an hour, when I would shut down the motor (kids waterskiing) it became hard to start. I had to give it more and more throttle while starting to get it to fire. Also, when it would finally fire, it wouldn't start right up like it normally does--it would sort of slowly build up the rpms, running kind of rough, then smooth out once up to rpm (in neutral). Then it ran great at idle, acceleration and at WOT. Engine gauge temp all day was around 135 to 140 degF.
Eventually it bogged down at idle and slowly died. Then it wouldn't start. Pulled the flame arrestor to find the choke plate CLOSED with the engine fully warm. Pushed on the choke plate--very high tension on the coil spring. Disassembled the choke, found the choke plate a little sticky in the closed position, lubed up the linkages well and put the choke back together with a lean setting. Ran the rest of the day but hard to start.
The next morning, pulled the plugs--they were still wet with gas from the flooded condition the day before. With engine cold, set choke per the manual. The coil spring hook to the right of the lever tab, then rotated CCW to lightly close. Started but again slowly went up to rpm; unusual. Watched the choke plate open up in a minute or two as the engine warmed. Ran better that day but still hard to start when fully warm, after an hour or more. Pulled the flame arrestor and AGAIN the choke plate was tightly CLOSED with a warm engine. Loosened the three screws holding the choke cover and it SPUN clockwise to relieve the tension.
1. Is this a choke problem? I noticed something in a manual that if the carb isn't set up correctly, the idle mixture screws can be ineffective (mine don't seem as effective as they should be), and the choke may not work right. My idle speed screw is turned almost all the way in to get the book idle of 650-700 rpm. Max RPM at WOT is 4600, top of the spec. I had the carb rebuilt 2 years ago and set the idle mixture screws and then the idle speed, but I didn't go through the whole carb set up procedure in the manual, so I wonder if something is set wrong. The engine ran GREAT for those 2 years.
2. If the choke is closed when cold, then opens correctly, why would it end up closed tightly with lots of coil spring tension when the engine got fully warmed? That has me stumped.
If the choke coil is suspected, the choke cover/coil is Mercruiser p/n 1397-2648 and is listed as no longer available--where would I get one if that's the right thing to try?
Thanks in advance.
Bt Doctur
Re: Choke Plate Closing After 1 Hour
your idle mix screws have nothing to do with idle speed, Adjust them for the smoothest /highest rpm.Then adjust your idle speed screw for the proper idle rpm.2CG parts can be obtained from auto stores
jtybt
Heck, you don't need the choke anyway. Unscrew it and remove. Don't drop the screws down the carb.
If you have to, hook up a manual choke cable. You should have plenty of mounting places on that set-up.:D
bigskiohio
Master Chief Petty Officer
just loosen the screws and turn the big black dial till open then tighten or adjast per manual but not as tight as they call for leave it open just a touch.
myoldboat2
That makes sense. When I adjusted the idle mixture screws, I used a vacuum gauge. The tag that used to be on the Rochester carb said "Mercury Marine 1351-5203A1" -- is that a 2CG?
Heck, you don't need the choke anyway. Unscrew it and remove. Don't drop the screws down the carb. If you have to, hook up a manual choke cable. You should have plenty of mounting places on that set-up.:D
I'd like to hear more about that. Does it cold start OK without the choke? Also, there is a fast idle cam on the other side of the carb--does that operate correctly without the choke?
Obviously, carburetors are not my strong suit.
myoldboat2
That's essentially what I did, except I did have the choke plate close lightly where I set it. But why would it end up tightly closed with a LOT of coil tension after an hour or more of running? As the coil heats up, it expands and the hook moves clockwise, allowing the lever to move clockwise (due to gravity pulling down the weight of the plate and the weight on the other side), and the plate to open. Why does it eventually close?
jtybt
Try wiring the choke open and try it. You can easily set your own idle speed for warm-up.
myoldboat2
While I'm considering going chokeless...
does anyone have a theory as to why a choke would start closed, open with warmth, and then close tightly with lots of coil tension once the engine is fully warm (1 hour of skiing with lots of WOT)?
Do these bimetallic coils ever go goofy?
bigskiohio
unless your heat tube is broke but i dont think so,that doesnt make sense you might have to delete the choke or go electric. pop the black cover off maybee the spring is broke or rod fell off.
Don S
Why don't you just take the thing apart and look at it. Something may have broken. If you aren't sure, get the manual or post pictures of what's in there.
myoldboat2
I had it apart and didn't see anything wrong, but what do I know...
I'll get some pics and post them.
I'm also going to try starting it without the choke plate.
bigskiohio
just give it some full throttlepumps and idle up should be okay without choke. let it warm up for a couple of minutes then should be good to go.
vxtech
just a suggestion ,but is it possible that spring is installed backwards and pulling choke plate tight
ziggy
just a thought. look at the fast idle cam. the cam the idle speed screw rests against. see if that cam has flipped over to the wrong side. if it has, the speed screw will not be resting on the cam, it will be missing engagement of the cam all together. if the cam flips to the wrong side. the choke plate will go full closed...
myoldboat2
vxtech, I believe the spring is in there correctly. As it cools it pulls the lever ccw (looking aft at choke on front of carb), closing the choke plate.
darn it, ziggy, I never thought of that! I wish I would've checked that when the tightly closed condition happened on the lake. Don't think I can replicate it on the muffs.
bigski, you may be right, I'm going to try it without the choke. But today went to pot the second I sat down at my desk, argh.
myoldboat2
My next post will have pics I took today.
I tried it with the choke plate wired open. It started perfectly when cold. When warm, I again couldn't get it to start without putting in a fair amount of throttle--corresponding to 2700 to 3000 rpm in neutral (I pulled it back before it got up there). I'm going to get fresh gas in the next few days and see what happens. I'm starting to think the hard starting when warm is not a choke issue. Maybe my carb is screwed up again. The engine oil was changed a few weeks ago and still loks brand new, no water in it. I lost my impeller and engine temp reached 190 a few weeks ago, put in a new impeller and pump and no issues since then, except this hard starting when warm, but that is also since I had the engine out to change the coupler.
I took the choke apart and didn't see anything unusual, not that I really know what I'm looking for. The coil tang is put in to the right of the lever, then the cover rotated CCW to engage the lever.
Please look over the carb linkages at the rear of my carb to see if anything looks SNAFU'd. Thanks.
myoldboat2
myoldboat2
myoldboat2
HT32BSX115
Re: Choke Plate Closing After 1 Hour **PICS ADDED**
Howdy,
Good clear pictures!!
You didn't indicate where and when you boat, but I only boat in fairly warm weather. I have an electric choke on my 454, had one on my 460 and when I had the 150 Mercruiser (with pretty much the same carb as in your pictures) I either disconnected the (electric) choke or adjusted it permanently open.
Unless you're in pretty cool weather, you might be able to just go without it.
Now having said that, your choke is a pretty simple device using that little piece of copper tubing to route heat from the manifold up to the bi-metallic "spring" (electrically heated in mine) you show in your picture. The spring when cold is adjusted to close the choke and when it warms up it opens the choke and takes the fast idle detent out of the picture....
You're obviously not getting enough heat up the tube to warm the "spring" and open the the choke once it gets running or the linkage is bent/binding and the spring cannot move it.
The tube might be plugged or the port on the manifold it's connected to is rusted/corroded shut or it's plugged with other debris. That should be exhaust gases going thru the tubing so the little housing that holds the "spring" also probably has a small vent to allow those gases to escape so that there's a "flow" of (hot) exhaust gases across the bi-metallic spring.
Also, it might just be adjusted incorrectly.
Regards,
Rick
