i cant get the pistons back in the bores
dr_bowtie
Re: i cant get the pistons back in the bores
regular rings have more spring pressure...this is the force applied to teh cylinder wall....
low tension are just that...smaller springs with less force...they are commonly known to lose tension if overheated...
BUT...the less force means less friction....less friction = more power...:)
Earie dearie
You might want to try using a ridge reamer to remove any ridge from the top of the cylinder bore.
fishingman220
nope, found the problem, it was the .165 rings. apparently from 96-00 chevy used alot of different odd ball ring sizes, but went to a few speed shops and they all said the same thing, so ordered them today and will be here tomorrow, i will get back to you tomorrow night after i try to install them.
jtybt
Tch! Tch! Tch!
Can't trust nobody!
Live 'n learn.
Indymike
From a thread in another forum........
apparently from 86-96ish GM used a piston with a shallow oil ring groove requiring shallow oil rings.
fishingman220
thanks, thats the ones i ordered, the sealed power e377k
fishingman220
THANK GOD!!!!!!!!! i got all 8 pistons in the bores and caps on and torqued down, and rotating assem. is done!!!:D it was thr sealed power E377K which was the .165 shallow groove oil ring with molly top ring. thanks for all the great help, keep an eye out i will post pictures when done and maybe a video of it running if i can figure out how to put it on here.
wca_tim
congrats!! have been following this one with interest... Glad to see you got it figured out
dr_bowtie
yes 86-96 calls for "Low-Tension" oil rings...these are the .165 rings for the oil groove...
book shows same ring for 4.3L V6 as well....
fishingman220
thank you for everyones great advice, the motor is finally done and going in tomorrow, just figured i would post some pictures of before and afterwards, thanks alot
