Hello, new to the forums and new boat owner! I have a 1997 evinrude 40 hp which runs awesome....my engine is equipped with the warning horn and also the warning gauge for Low oil, no oil, overheat, and check engine. When I turn on the ignition or start the engine the horn beeps once like it should but then I get a long beep for about 20 seconds and the warning light for overheat comes on. The motor is compleatly cold so i know it's not overheating, so I took out the temperature switch and tested it with an ohm meter and do not have continuity...so I dont think switch is bad cause when it overheats the switch compleates the circut correct? Any help would be appriciated Thanks!
VRO is disconected if that could be an issue
