um0RION
- Aug 28, 2009
- 88
Hi all, first post. Im a new boat owner, and wanted something for my camp I could fish from and do some entertaining. I found an 18' 1991 bayliner capri with a 120hp evinrude engine, complete with trailer, for $600. Now im going to try to do some repairs, and I need some help
1st and probably most pressing problem: The drain that runs along the fiberglass in the bottom of the hull doesnt drain water well. I pushed a snake into the hole to drain the water, but after 5' or so (pushing towards the stern) the snake stops. If I push harder, I could feed in about 10' of the snake. If I feed from the other direction I have a similar problem, it goes in only so far, then stops. My question is, how does the drain run? is it a straight 1" tube from front to back? It feels like there is some cavity the snake gets into, and cant find the outlet hole. Is there some sort of tube that might have come loose and should be connected? If there is, it is under the floor and I cant get at it. If this is the case, I might have to pull the floor up (really hope it isnt that). When I bought it, there was probably 4" of standing water in the bottom of the boat, which we managed to drain, but it was incredibly slow. Any idea what might be wrong?
2nd problem: The steering controls appear to be frozen. I cant move the engine at all with the steering wheel. Is there some lock somewhere that might prevent it from moving, like when traveling? I havent tried any penetrating oil anywhere yet (only owned it for 2 days) but its something I could work on this weekend.
Other problems include the electrical for most of the boat not working at all, the only thing that works is the power tilt/trim. No fire in the engine, but I did find two disconnected wires which i reconnected to no avail. It's been sitting for probably 2 years, but it WAS fogged/winterized before it was carefully and tenderly stored behind a house in the middle of the woods without a cover or protection, then moved directly under where a roof drained into.
Fixed these ^^ but need steering help on page 3.
I can deal with electrical, but those first two problems are out of my league. Help please?
