moving up a size- spun hub and rev limit alarm
gvegas88
I've got a 2005 Suzuki DF15 on a very light 14ft wooden jon boat that weighs maybe 150lbs + 100lb engine. There is usually two starving college students and at most 50-100lbs of gear. When I first got the engine for the boat, at full throttle the engine would set of the rev limit alarm so I just adjusted the throttle so it wouldn't rev as high. Well today I spun the hub on my 3x9.25x9 prop and I was thinking about getting a larger prop and opening the throttle back up instead of fixing the one I have. Should I just go up an inch in diameter? I can get the same prop but with 4 blades in stead of the 3 bladed one that I have.
The Operating range for the engine is 5400-6000 RPM's
The gear ratio is 12:23 (1.917)
hwsiii
Re: moving up a size- spun hub and rev limit alarm
Gas, you need a 4 blade Solas Amita prop, it will bring your RPM down into the right range. You also will be able to arry a heavier load at faster speeds and your hole shot and aeleration through out the omplete RPM range will be superb. I promise you that you will onsider it to be one of the best things you ever did to make your boat muh better.
Whereas if you get a 10" prop your RPM will drop down about 600 RPM and your hole shot and aeleration will be MUH reduedf rom what you have now.
You an buy it right here at Iboats
Price: $55.99
You Save: $20.01
Compare: $76.00
Discount: 26.4% Off
Add Amita Aluminum Propeller 4113-093-09 To Your Cart
Propeller Specifications:
SKU:#4113-093-09
Manufacturer: Solas
Brand: Amita
Material: Aluminum
Diameter: 9 - 1/4?
Pitch: 9?
Blades: 4
Rotation: Standard (Clockwise)
Usually Ships Within:
H
gvegas88
Sounds good. I ordered the 4 bladed prop so I hope it works. Thanks
hwsiii
It will, but please ome bak and give me a report of WOT RPM and speed.
H
