FishingBuddy
Thread starter- Joined
- Jun 28, 2009
- 12
I have a 2001 Mercury 90 ELPTO on a 2001 Lund Mr. Pike 17. Everything seems to be working fine.
However, I have had two cell phone chargers die when connected to my 12V (cigarette lighter) power outlet. The outlet is working fine for my air pump and other devices.
I recently installed a new Lowrance HDS5 GPS/Sonar. I noticed that about 1 in 5 times I start the outboard that the HDS5 will reboot. This made me realize there must be a voltage transient that is occurring when I crank the motor. When I first plugged-in the phone chargers, they worked OK. Later they were dead. I wasn?t able to observe if they died when the outboard was being cranked.
I believe the transient to be in excess of 35V and beefy. I am the manufacturer of the two cell phone chargers that died. The chargers are designed to operate at a constant voltage of 32V, and are further designed to withstand (immunity) commonly specified vehicular transient waveforms (cranking, load dump, alternator whine, etc.). These are not cheap chargers.
I have an oscilloscope and can and will characterize the transient waveform. I only lack a flusher to get water to the outboard while testing. I am technically capable of tracking down the source of the transient. However, I am inexperienced with the Mercury outboard and whether the outboard or the (Lund) boat?s electrical system has any form of transient suppression built-in. So, I?m hoping to tap into any experience that the readers of this forum may have. For example, I don?t even know whether my Merc has a generator, an alternator, or a magneto. And, whether the starter motor has or hasn?t a separate solenoid, etc.
Perhaps:
1. I have a faulty component in the outboard. There will always be some level of transient when cranking the outboard, but the faulty component is making the transient larger than ?normal?. This is what I guess the matter to be, but the problem is masked because my motors starts right up and seems to be working just fine.
2. There is a component in the outboard designed to suppress this transient, but this component is missing or defective or out of circuit.
3. The transient is there, is not different from other motors/boats of the same type, but the equipment I have (Lowrance HDS5 & the cell phone charger) are particularly susceptible. I really doubt this to be the case.
If I do not have a faulty component in my motor, my obvious option is to install transient suppression componentry. Now, would the transient suppressor(s) be installed at the source or on the load side (i.e., at the 12V power outlet, and where the HDS5 is wired into the system)? I can imagine the solution being either way.
Thanks in advance for any comments.
Perhaps:
