timdan94
- Jun 23, 2008
- 480
My Unlce has a yamaha 4 stroke 225 that started and idled fine for about 15 min then started to what seemed like miss and buck then died. I got it to restart but then it idles for a second then starts to drop in rpms then it starts to pop like it is lean sneezing then dies. Some times it will keep running but the rpms are too low then after a little while it dies. I found a line on the top of the engine that looks like a breather for the oil that was split so I changed that and cleaned up the oil but it still continues to pop buck and stall. If I disengage the shift and rev the engine up it will run fine. I'm at a loss and I'd really like to get this engine running so I can go fishing seeing I'm at his place in va and will be leaving tues.
