mirrocraft v-hull ... add a floor ??
coolbikeguy
hey guys. i have an old ( 1965 ish ) mirrocraft v-hull that my dad had and used just as a fishing boat. it has a newer ( 1990 ) Merc 25 w/tiller. id like to add a floor in the boat to make more user friendly. how should i go about doing this ? the boat never had a floor in it before so im not sure where to start and how to support the plywood. i read a previous post on plywood grades and what to use so i think im good there. i will be using some sort of carpet aswell. thanks guys, scott
bigredinohio
Re: mirrocraft v-hull ... add a floor ??
Do you have a picture of the interior of the boat and the length?
coolbikeguy
i will get some pics tomorrow
reelfishin
If it's an aluminum boat, I have two buddies who put floors in their 16' Mirrorcraft boats. Both of there's use many rounded top ribs and no stringers.
What one did was to lay a center 2x4 along the keel, and two outer 2x4" laying flat on each side. He made three panels which set in place with no fasteners. He notched the outer 2x4s to fit slightly over the ribs on each side. The keel runner sits vertical. Each panel is also framed on the edges underneath with lighter wood. It makes for a very usable set up and since the panels are removable, they can be stored indoors when not in use and you don't have to worry about dropped bait rotting under the floor.
Another buddy removed his seats, ran a slightly taller keel strip out of aluminum, then he cut and riveted in 1/8" thick aluminum diamond plate with foam flotation under the deck and foam pipe insulation filling any side gaps to prevent anything from getting under the sides.
He then camo painted it along with some sand for traction. I like that set up the best, it's clean looking and light. It's also super easy to clean and will no doubt last forever. He mostly only hunts with that boat but does do some fishing. Both are Mirrocraft Lake Master hulls from the early 70's.
Lion hunter
With a 25hp, I'm guessing it's a 14'.
I used 3 2x6's between each seat. Cut them in a 1/2 moon shape so they ran from side to side and screwed a piece of 3/4 to the top. I also ran a piece of 2x4 between each 2x6 so they wouldn't rack. I drilled holes and put rope handles in each side. I just pull them out when I'm done for the year and out in the garage. I did paint mine with porch paint and antiskid to seal it. But if it dies rot out I'm out $35.00.
