green4themoney
Thread starter- Joined
- Jul 21, 2004
- 318
hey guys, alright i need your input on this problem, i had my 1970 merc 9.8 hp out 2nite after everything was fixed and ive had it running awesome the past few weeks, but tonight for some reason it only wanted to run on one cylinder ONLY at low rpm, when i opened it up it ran fine, i was with my dad and hs gf and wanted to give them a tour of the lake and felt a little embarassed of how the engine wouldnt idle..... the only thing i have changed since was i used some gas from one of my other cans that i have purchased in june and it was already mixed 50/1 everything else was fine with my fresh can of gas now i use the old gas then this happens, so i take the engine home, pull the plugs and im getting GREAT spark on both cylinders, so at this point i asume there is water getting into one cylinder or one cylinder isnt getting gas at low rpm's... so i pull the exaust cover off to see if im leaking at i see the motor side of the baffle plate and its got like a light light green milky colour to it, which is telling me im not getting fire, but this colour itself im not overly sure if it indicates water is getting into one of the cylinders?
so i think i have it narrowed down to a few things
-for somereason the reeds have frozen and will only open at higher RPM's
-im getting water into a cylinder at low RPM's and at high RPM's the exaust pressure is keeping it out
- i have an air leak somewhere that is leaning out one of the cylinders
- maybe the gas was just bad and for some reason only one cylinder would burn it
i have a new powerhead gasket set on the way
the problem is fine at WOT
it only really starts to cut out and cant decide if it wants to run on one or 2 cylinders at MID throttle and at idle it is most def running on one cylinder
anybody have any insight on this problem? what are your thoughts? any help would be appreciated
