40hp mercury solenoid bad
chris clerkin
I had to replace the solenoid on my mercury out board about two months ago only used boat a few times and now it seems the solenoid is bad again is this a sign of a deeper problem or maybe just a defective part. please give me your thoughts,thanks
rosser1
Re: 40hp mercury solenoid bad
starter solenoid or what? what is doing, or not doing. check all connections make sure everything is snug tught. and grounded. and let us know results
chris clerkin
starter solenoid first time I had to jump accross it to get out of the water this time the starter will not disengage Thanks
rosser1
turn flywheel back and forth , that should disengage starter from flywheel
