marinemike43
Thread starter- Joined
- Jun 23, 2009
- 95
OK,here is the story.
Boat ran good at idle,just would not plane out(chuged and then died)
Saw fuel in the tell tale so replaced fuel pump.
Then it would not start after that,saw alot of gas in the carb after trying to start.
So I took the float out and checked the needle and seat,didnt look that bad as far as gunk. ( Simi cleaned the carb the best I could with out a kit.
Put it back together and it did start . ( also cleaned the plugs as they were black and fouled from gas)
Now it will run but like crap,wont idle and after it dies noticed alot of gas still dripping in the carb.
Do I need to just rebuild the carb with a kit?
Thanks MIke
Thanks MIke
