Re: Mercruiser 233 to GM
Thanks Bondo, I'll keep looking. Got time,just getting started on transom.
Ayuh,... My thought on what you're lookin' for,... Mid/ Late-80s,... 85, 86, 87, Alpha 1, 260hp....
The Alpha 1s are the Most adaptable, for the Largest Used Parts selections... That means Cheaper to Fix...
The Alpha 1s have Better transom assembley's, especially Hyd. Trim wise...
The Earliest versions of the Alpha 1s are also the Most Greaseable transom assembley's...
Greased Greaseables don't wear out...
Those Vintage also are using the T-Bolt IV igntion,.....That's a Big Plus...
The only downfall of that package is they were still using the Rottenchester Carbs back then,...
Updating to the Weber/ Edlebrock can Fix that though...
Good Luck,....
