1991 Johnson 150hp cutting out at 2800-3000 RPM
DFA
New guy here, but I really need some help. My boat has been sitting for about 6 - 8 months(same gas 1/4 tank) and ran great last time I took it out. Anyway, I took it out and the boat started up a little slow, but ran great once it started...It ran normal through the no wake zone, but when I tried to take off it started cutting out at 2800 - 3000 RPM's. It's been at least 5 years since the carbs have been worked. A friend and I put a compression gauge on it and all 3 cylinders on one side had 100lbs. compression, the other side 1 cylinder had 100 lbs. one cylinder had 95lbs. and another cylinder had 90lbs. I don't have any idea where to go from here except a card job and new gas, so any help would really be appreciated
junior1113
Re: 1991 Johnson 150hp cutting out at 2800-3000 RPM
compression is good. good starting point get rid of gas. rebuild carbs.
DFA
Thanks Junior...Any more suggestions??? A friend of mine told me I would maybe need a power head, but I dont think I do.
jonesg
$4000 for a new powerhead vs $120 for 6 carb kits..
hmm tough decision.:D
DFA
Yeah Jones not a tough one at all
DFA
Hey guys, just wanted to give an update. I hae good news...I clean the exterior of the engine really good, adjusted the throttle linkage, and hook up the water hose attachment and the boat ran like new. I don't know what happened, but I am going to run a bottle of seafoam through it with some new gas and see what happens. Thanks for the help guys
junior1113
advise-running motor on the hose is way different than under load in the water.
