jriegle04
Thread starter- Joined
- Jun 1, 2009
- 179
1985 Johnson 150GT J150STLCOH
I have what appears to be gas/oil mix on the engine block. It looks like it is coming from the upper bypass gaskets on the port side. Is this a reasonable assumption? I have been noticing a performance decrease with a lot more than expected gas oder coming from the engine after a WOT run. I have also been having a lot of sluggish acceleration. I just rebuilt the carbs, upgraded from VRO to OMS, replaced the stator, power pack and 1 coil on that side and all spark plugs. I can't seem to figure out what is going on. Compression is all within 10% all being above 110psi.
