freeisforme
Thread starter- Joined
- Mar 23, 2009
- 184
I picked up a great running 1989 Evinrude 110 today, its a saltwater motor that had a new power head last fall. (143 psi compression on all 4 cyl.)
It runs perfect, pumps water and cost me nothing.
The problem is that the lower unit leaks water like a sprinkler with the ears on it in the yard, water squirts out all over. It has clean oil, shifts fine but is well pitted from the inside.
My question is, how durable are these gear cases? I did a pressure check and all is fine now, and it had a new w/p installed in March.
The motor will also need to have power tilt and trim added, but I have a donor motor which will supply that. The mid section and bracket are clean, no real corrosion there at all. Just the lower unit.
Off hand, what years will interchange lower units?
I don't mind the external water leaks in the case, and it has good water pressure when running, but I am concerned about the gear case being close to perforating into the gear oil area.
