fm elliott
Thread starter- Joined
- Jun 22, 2008
- 21
Vacation this year involved a month of building a 30' pontoon boat and fitting a 1970 Merc 100hp (model 1000ss). Finally with 3 days of vacation gone this week. We took her out yesterday, and the boat and motor ran great. Started quick and ran smooth. I noticed a little leaking around the fitting on one of the gas tanks. Today when idled down, she skipped a little and shut off, and hasn't fired since. The tank was down to a couple of inches in the bottom, so I switched to the better of the 2 tanks, still with no luck. The gas line pump up bulb didn't seem to get tight at first, but finaly did in the end . Still didn't crank.
I removed the hood and when facing the front of the motor, saw a rubber hose on the left side, that had disintigrated, and wasn't connected to the motor. this hose is one of 2 or three that loop from the upperr block, to mid then lower block. I'm worried that these are water hoses, and the engine is damaged, although the motor spins fine and isn't locked up. Also I kept a close eye on the water exit port and it had been "peeing" water like it should.
Any ideas to help put this vacation back on track will be appreciated.
Thanks FM Elliott
Thanks FM Elliott
