Re: Quick question - hopefully easy answer...
Slightly older model pictured below but the knob arrowed turns through 180?. In one position the tilt is locked in the other it releases the catch and the motor will then tilt.
You may also have a shallow water drive facility that lets you support the engine part way between fully tilted and fully down
BTW that carrying handle is only plastic I've broken it now!
