Electrical double check
cadet917
I picked up a 15' fisher with a side console. I had to gut the whole thing and put a new floor in. Im in the process of hooking up the new electrical system. I ran main leads up to the console where i have a ground board and a hot lead board with fuses. i have my bilge pump and livewell pump on a 3 way switch. And i have the running lights, and horn on separate switches from the panel. I am planning on just wiring the DF and VHF to the panel since they have a built in switch. Is there anything else i am missing? any suggestions for the wiring?
jriegle04
Re: Electrical double check
it sounds like you have it under control. how hard was the floor replacement?
cadet917
the original floor was foam with beer can thin aluminum over it. i removed all the foam and replaced it with 3/8 plywood. i cut it to size, soaked it down, screwed it down and let it sit for a few days. now i have to seal it. this is gonna be a salt water boat so i dont want any foam in the floor to trap water.
