calincoltsdad
Thread starter- Joined
- Jul 17, 2009
- 33
I know a head gasket can cause overheating in a car. But can one cause overheating in a marine engine even though there is no water in the crankcase. I have an enormous amount of steam coming from the oil fill cap almost like a steam engine it just boils out once its at operating temp. When I take the cap off the engine idles up an extra 100 rpm and lowers 100 rpm when I put it back on. What can be causing this? I plan on checking the compression Mon. Can exhaust be coming from a bad head gasket and pressurizing the cooling system by going into the coolant valleys? The engine is a 4.3L V6 yamaha. Raw pump is new, changed circulatory pump, I hope its the right one. The impeller looks different than the one that was on there, not sure if it is supposed to be a reverse flow or not. Had to get on that fits a 1966 chevy small block to match the one on the engine completely. Risers are clear, new therm. (140), both exhaust manifolds have small cracks on the bottom of them on the out side that have been patched with jb weld. I dont know what else to do to this engine.
