Mariner 40 Hp Magnum Oil Injected.
Possibley a 4cyl
Unsure of Year (here are the possible serial numbers, I was told its 1990):
1-8871-C
016905
OC 287943
I recently just starting having an issue with the power trim not able to trim up. When motor is not in gear I can trim the motor up and down all the way with no problems, but when in gear it seems there is not enough power to trim it up.
I checked the oil level on the cylinder and red oil came out as soon as I opened the screw. I don't believe there are any problems with the oil level.
Hoping its an easy fix!
Possibley a 4cyl
1-8871-C
016905
OC 287943
