Proper fuel pressure for a Suzuki dt65 (1989, i think)
ozzie101
we want to put an external fuel pump on our dt65. what is the proper fuel pressure?
the motor runs at 3/4 throttle for awhile and then bogs down, pull the throttle back to 1/4 -1/2 for a little bit and then it will take off again at 3/4.
pumping the bulb while at 3/4 doesn't help. not sure about where and how to change internal fuel pump.
thanks for any help
deejaycee_2000
Re: Proper fuel pressure for a Suzuki dt65 (1989, i think)
Adding an external fuel pump is a bad idea, rather just replace the fuel pump diaphragm as it is a cheap and easy fix ...... see www.brownspoint.com
