Battery Selection
janpetemar
Have a 1967 Larson Lapline with a GMC/Chevy engine, Model# CU14D. The engine is a 120 hp, four cylinder, twin carb with a OMC Stern Drive with electric tilt. What size (group) and amp battery should I install?
Re: Battery Selection
Ayuh,... A 550cca is about Minimum....
But,...
With Batteries,... More power is Always Better,....
JustJason
Nobody ever complains when they DON'T run out of power... buy the biggest MARINE STARTING battery you can afford/fit in the boat.
janpetemar
Thanks for the info.....was afraid that the marine battery I have that I used with a grey marine 8 cyl engine would be overkill and possibly do some damage.
Isaacm1986
the best battery period is a marine optima, i have had mine for 7 years and still running strong!
cr2k
A decent group 24 is plenty of battery. If you sit for long periods with stereo or other battery use then up grade to group 27 (you may need a bigger box or mount.
janpetemar
Thanks for the help peeps.....decided on a group 24/850 cca :)
