Popeye USN
- Jul 13, 2009
- 10
Replacing the deck on my boat. It's a Hurricane hull with a pontoon type deck. I want this sucker to be water tight so the only through deck hatch will be over the aft centerline gas tank.
I plan on putting the trolling motor battery aft with the other batteries, and running a cable under the deck to up to the trolling motor. Any foreseeable problems with this?
Right now the two 12 volt engine batteries are connected in parallel which, I think, produces 12 volts? Here's the question? If the new trolling motor is 24 volts, how would you now install the batteries? One for the engine, and two in series for a total of 24 Volts? Can they be charged from the engine set up like that? Would a Perko help? I'm confused!
