200 HP Merc, idles but pops and snaps with throttlw
notfishing
I have a 200 HP Merc that idles fine but when I give it throttle it pops and snaps. I've replaced the plugs, fuel pump, filter, bulb. What should I try next, anyone?
j_martin
Re: 200 HP Merc, idles but pops and snaps with throttlw
Which 200?
notfishing
It's a BlackMax, 1981
notfishing
V6, carburated. Not sure on the 2.0 or 2.4. Mounted on?
j_martin
I wish you weren't so verbose.:D
First check the link n sync. If the linkage and timing are correct, then go after idle mixture. If it's adjustable, richen it up 1/2 turn at a time. If not, it's carb cleaning time.
Assuming it idles smoothly on all 6, reeds would be fine.
hope it helps
John
notfishing
My apologies with lack of detail! I'm new at this forum thing and not sure how wordy to be.
I called one mechanic just now and they want to run some tests first. I'm wondering if it might be the stator. Some of the previous posts mention that.
It didn't come with a manual. Where could I find the info on the timing and linkage?
macdaddy
Link and sync: http://forums.iboats.com/showthread.php?t=168855
