360 light flashes when motor is running
LaneyAnne
360 Light Flashes when motor runs
Hi everyone, back again with another problem. I recently removed the bridge from my 27 Sportcraft to turn it into a traditional hardtop, and to fit it in my boathouse/hoist. Every thing came out better than expected except for two guages reading incorrectly and a 360 light that flashes to the motors timing (or so it seems). Works perfect when the motor is off but as soon as I start it the light flashes dimly, and the anchor light goes almost completely out. All I did here was cut a white, a black, and a gray wire and reconnected in a different place. The fact that I took an additional nav light switch on the bridge out of the loop could be the issue.
Any advice??
Thanks in advance!
Laney Anne
Splat
Re: 360 light flashes when motor is running
More than likely a ground issue. Start by cleaning the contacts where the negative wire grounds.
Bill
LaneyAnne
Thanks Bill, I will do so. I think I just might have to disconnect and rewire all three wires. Maybe I did a poor job splicing?
I appreciate the response!
Laney Anne
Zeeter
You have a ground problem Ground things to the battery not the engines.
LaneyAnne
Thanks for the responses Zeeter and Bill, problem has been rectified! I regrounded the wire and removed the old one which was grounded to the bottom of the boat, wet, and corroded a bit.
Everything works just fine now.
Thanks!
Laney Anne
