Mr.Stuart
Thread starter- Joined
- Jul 18, 2007
- 701
I thought I'd throw this in here for what it's worth.
I'm also a member of a farm tractor forum, my tractor broke down and I've got it tore apart and am in the process of fixing it.
I was doing a compression test on the tractor engine (a Briggs and Stratton Vanguard) and had posted my compression readings in the tractor forum, and had made the comment that (to my knowledge) most older outboard boat motor manufactures, (at least Evinrude and Johnson) don't list anything about compression readings in regards to what they were (or were supposed to be) when the outboards were new, I ran into the same thing with that Vanguard motor, I couldn't find any info on what the recommended compression readings were supposed to be.
I got a comment from a poster about that, what he said didn't really make any sense, but thought I'd share it anyway.
he said "Most small engines have some form of a compression release that cause a false reading, your Vanguard doesn't seem to, but I believe that's the reason that small engine manufacturers don't use them.(compression readings)"
I've had the cylinders apart on at least one of my outboards, and I've never seen anything that would cause a compression release, that in turn would cause a false compression reading.
but, on model airplane motors, (OS MAX is one brand) some of the older engines used what they called a dike ring set, where it didn't build compression until it was running at a high rpm, turning the motor over slowly (on the OS model airplane engines) would produce very little compression.
so, I guess this leaves me with the thought and question, why didn't the outboard manufacturers (in my case Johnson and Evinrude) ever provide a recommended compression reading in any of their manuals or motor literature?
