OK quick prop question???
WAVENBYE2
No one seems to be on the prop forum. I have a quick prop question?
48 16318 A4 19p. I know that 16318 is the S/N and 19p is the prop pitch, and I think the A4 is (cup) <curve whats the 48?
180shabah
Re: OK quick prop question???
If I had to guess, I would say it identifies application (ie, alphas, bravo1's and large gearcase merc OB's, they all have the same shaft/hub dimensions).
WAVENBYE2
ahh OK, no one seemed to answer about the 48, makes sense.
The entire "48 number" is the Merc part number. The 19P is added for your benefit, so you make sure you are getting the right pitch. You cannot buy a different pitch prop with the same "48 number".
Trying to break it down is silly, since Merc may or may not have simply assigned the next allocated PN to it. The A4 likely refers to an update to this prop(from A3) that changed the part to add cupping or different paint or different type of hub, etc. Without detailed info from merc, you simply do not know why the part number was changed.
