Question On Towing with new Vehicle
waterdawg69
I have a 18ft celebrity 181, and i just bought a 2008 Mitsubisi endevor it is 3.8 6 cylinder Fwd Im going to put a hitch on it. will i have any problems towing with this vehicle? Thanks
JB
Re: Question On Towing with new Vehicle
Find out what the rig weighs and what the car is rated to tow. If the tow rating is about 30% higher than the rig weight, ready to launch, you will be okay.
Shrub88
The tow rating for the FWD model is only 2,000 lbs.
If you had AWD, it would be 3,500 lbs.
Sounds like too much boat for your vehicle.
waterdawg69
there is a tag on the trailer that say 3500lb but don't know if its just the amount of weight the trailer can handle or something else, thanks for the replies
QC
Trailer GVW, not boat weight ^^^^. Only way to truly get your weight is a truck scale . . .
waterdawg69
my vehicle can be driven as a auto/5 spd and has Traction Control button would the 5 speed or Traction control help any on pulling boat.
QC
Yes, but the issue is the vehicle's tow rating, not necessarily its features . . .
waterdawg69
Ok Got home and the trailer tag says GVWR 3500
GAWR Front 2700
On Inside of door jam on truck says GVWR 5346
GAWR RR 2745lbs
gawr fr 2745 lbs
bruceb58
GVW of your truck has absolutely nothing to do with what it can tow.
The sticker on the trailer indicates that maximum gross weight of the trailer and load. That is just the maximum rating of the trailer and says nothing about the weight you have. You need to weigh your boat/trailer.
jdsgrog
More info on the boat would be helpful. What year? Outboard or i/o? If outboard, what motor (year, model, hp)?
The 2008 Endeavor has a MAXIMUM tow rating of 3500lbs with the 3.8 liter engine (from my research it doesn't matter if it is fwd or awd). You need to see what that means from the car manual. Usually a maximum tow rating requires the factory tow package (which includes transmission cooler and sometimes modified suspension) and likely a weight distributing hitch and trailer brakes.
jkust
It sounds like you don't have the tow package if you are adding the hitch. The tow package really adds a lot to a car that otherwise would tow poorly. I would guess without the tow package your are not rigged correctly even with adding a hitch. With the package, I bet you would be all set.
waterdawg69
thanks for the replys it is a 1989 with I/O trailer is single axle. i would be adding a trailer hitch. im mostly on just a straight away road, and lake is only 5 miles away where i ould be going. i do not travel with boat.
Shrub88
For that short of distance, I would think you will be OK.
Not a Mitsubishi expert but this is what I was looking at:
http://www.carpages.ca/article/2008/01/03/2008-mitsubishi-endeavor-buyer-s-guide
# Type: 4-door, 5-passenger midsize SUV
# Layout: Front engine/front-wheel drive/AWD
# Engine: 3.8-litre V6, SOHC, 24 valves
# Horsepower: 225 @ 5000 rpm
# Torque (lb-ft): 255 @ 3750 rpm
# Transmission: 4-speed automatic w/manual mode
# Tires: P235/65R17 mud and snow
# Curb weight SE FWD: 1800 kg (3969 lbs)
# Curb weight SE AWD: 1855 kg (4090 lbs)
# Curb weight LTD: 1890 kg (4167 lbs)
# Wheelbase: 2750 mm (108.3 in.)
# Length: 4830 mm (190.2 in.)
# Width: 1870 mm (73.6 in.)
# Height: 1710 mm (67.3 in.)
# Ground clearance: 211 mm (8.3 in.)
# Towing capacity FWD: 907 kg (2000 lbs)
# Towing capacity AWD: 1588 kg (3500 lbs)
Dave1251
NADA list this boat with a 3.0 engine with 2,500 dry weight. You need to add battery (50lbs) gas (6 lbs per gallon) and trailer (est 1,000 lbs) so the boat and trailer in real life is close to 4,000 lbs. Why would you buy a new car and void the warranty on the tranny?
jdsgrog
Towing five miles will not kill the vehicle necessarily (though I would not recommend it due to other safety issues). But with a boat that heavy and a front wheel drive only, you may have a hard time pulling the boat back up the ramp, especially if it's wet. I guess what I am saying is that there's a lot more to consider about towing a boat (let alone anything) than just if the vehicle can tow it.
