triplebogey
- Jan 29, 2005
- 9
Hi all,
First I've got the determination to fix this thing myself, but not the technical expertise so please bear with my ignorance. I've attached a few photos to illustrate my dilemma since my terminology may be off.
When I turn the ignition, I hear a click which I assume is the starter solenoid but the engine does not turn over. Also, if I try to trim up or down on the power tnt, I hear a click but the motor does not respond. I've attached a photo of what I think is the solenoid with my finger pointing at the positive post coming out toward the starter. Since I don't know how to use a multimeter, I ran a test light on the positive lead coming into the solenoid and it lights up. I also tested the smaller yellow/red lead which I assume is the ignition. This also lights up when I turn the ignition switch and attempt to crank the motor. However, I could not get the lead coming out of the solenoid to light up under any scenario (the one my finger is pointing at). At this point I'm assuming the solenoid is bad because I'm getting juice in and nothing out. Anyone have any thoughts on what this could be?
FYI - I also checked the shift interlock switch per other posts I read and mine appears to be functioning properly.
