2006 115 hp 4-stroke Yammy WOT RPMs ?
CaptainDavidM57
I have a 21 foot SweetWater Tritoon Boat with lifting strakes. On it is a 2006 115hp 4-stroke Yammy with a 13.5" x 15 inch pitch prop. From the performance bulletins I have read for this type boat I should be getting at least 5800 to 5900 rpms at wot. I am getting 5200, what is robbing me of RPMs ?:confused:
Casco Bay Outrage
Re: 2006 115 hp 4-stroke Yammy WOT RPMs ?
The WOT range for that motor is 5500-6000. Getting 5800 riding alone with no passengers would be the appropriate setup.
When you operated the boat and observed the RPM's, what was the load; number of passengers, gear, fuel load etc?
What is the brand and model of the propeller, aluminum or stainless steel? 3 or 4 blades?
The lack of RPM's is not the motor. It is most likely the propeller size and pitch and/or the mounting height of the engine on the transom.
A performance report is usually skewed to get the best performance so the boat is lightly loaded, <1/2 tank of fuel with no passengers in warm weather on a calm body of water. Was the report you saw for the exact year and model, similar weight and engine?
CaptainDavidM57
Thank you for responding
There was about 12 gallons of fuel, 3 people (about 500 lbs), not alot of fishing gear, but I did have a troliing motor that takes 2 12v batterys, with 3 people (about 500 lbs).
The prop: Solas Amita 3 Blade Aluminum 13.5" dia. X 15" pitch SR
The performance reports were for a similar pontoon boats but not exact. Most of the perfomance reports I looked at showed the rpms between 5500-6000. The owners manual to my motor shows a 5800 WOT.
From what you are saying, I may need to get a different pitch prop or just leave it alone the rpms are fine ???
Casco Bay Outrage
The basic concept is to rig the motor with a propeller of the correct diameter and pitch so that when light, you reach 5800-6000.
If you plan to run >80% of the time with a load, prop it for that load.
Every model of propeller is designed for certain uses. Some props are 2 bladed (sailboats) or 3 or 4. I am not familiar with that brand. Also know going down in pitch and then switching to another brand is not always wise since propellers can have a different blade shape. Not apples to apples.
Basically, if you drop down in pitch, (2 inch increments) you will gain ~150 to 200 rpm's for each 2 inch drop if you stay with the same brand/model.
Before you go throwing $250+ at a new propeller, post your current setup and prop info in the propeller forum.
While some dealers will let you lend out props for testing, I have not found many who do it.
Pontoons may have certain attributes that are addressed by a certain type of prop. A dealer may be helpful.
Hope this helps.
CaptainDavidM57
Yes this helps a lot. Thank you very much for sharing your knowledge and helping me on this.
