1979 Lund Restore
sieg100
I'm beginning to retore a 79 Lund 19' boat with a 288 Mercruiser I/O.
Condition: Motor locked up. Starter a ball of rust. The rest looks ok but haven't been able to test anything yet. Carbs cruddy looking but rebuildable.
A 2x2 section of the floor in front of the motor soft where it looks like they cut a section out to get to the fuel tank and replaced it with 1/2" plywood that wasn't treated or glassed over. A small section of the floor to the left of that has the lamination separated. Other than that, the rest of the floor is solid. The trusses that I can see appear solid.
Has buckets in front and 2 small seats in the back. Seat look ok with some fade and no cracking or tears but I plan on new seats anyway.
The outside is white and shows some oxydation. I think that it will clean up good with a little wetsanding though. This will probably be the last thing I do.
I realize that I will have more in the boat than its worth, but by the time I'm done it should last many years. With a better used boat, I'd still have to replace things from year to year. Since I'm not planning on selling it, a little more than its worth tied up in the boat doesn't matter.
So what I plan on and the order I plan to do it is as follows:
1) Buy a rebuilt engine.
2) Rebuild carb.
3) I'm sure that many of the components will be fine, but I'd like to replace as many as I can anyway.
4) Repair floor
5) Replace cables
6) Replace all seals in stern drive
7) Install engine & stern drive and take a test run
8) Remove and refinish all wood strips around the boat
9) Replace all vinal surfaces with new vinal. Like to change the color scheme while I'm at it to a different scheme. Install new carpet.
10) Buy new bucket seats. Something a little more modern looking.
11) New steering wheel for the same reason
I'm sure I'll find other things as I go along.
I've rebuilt cars and remodeled homes, but this is my first boat. I enjoy doing this stuff so the work itself doesn't bother me, but I'm not a rich man by any means so any ways to keep costs down helps. I'll have a lot of questions as I go along and it will take the winter to get alot of it done with plans on installing the engine as soon as next springs weather permits.
Anyone who wants to assist as questions arise, please bookmark this link as I'll be posting my questions to this thread (though much shorter..LOL)
So, for my first question:
I've been looking around at rebuilt engines. I found one place that lists 79 305 longblock chevy for mercruiser at $1188. But they also have a 79 longblock 305 chevy engine for $879. I can't see anything unique about the engine itself. What would be the difference? If the one for 879 is the same, I'd like to go that route. But I don't want to order an engine that won't fit. Any feedback on this is appreciated.
keepNitreel
Re: 1979 Lund Restore
That is the case with most of the older boats, mine is a prime example. The only way I could turn a profit for it would be to sell it to sell it to a person that doesn't know anything about boats and blind:D
But I did not start this restoration just to turn around & sell it, I plan on keeping her and passing it down to my 10 yr old & once she has kids, she can pass it to them and so on:cool:
Sometimes the worth is not valued in money but in the meaning and memories. That's priceless!!!
TK
If I am understanding your question...why the price difference.
I do not know all the changes, but there is a difference in a marine engine and a automotive engine. etc. freeze plugs, journals and bearing plus a host more. Plus the flywheel for the mercrusier and bobtail are different than automotive.
Everything that I have ever done and heard was stay with the "marine" block.
I am sure more will pipe in as the day goes on.:cool:
sieg100
I am aware of the freeze plugs being different, but I can pop those out and replace those with marine plugs easily enough. The flywheel has me concerned though. Anyone know more about this area?
sieg100
Actually, rebuilding the engine on this isn't completely out of the question yet but it looks terrible from what I've seen so far. I'll know more about that when I get all the components pulled off and get it out of the boat so that I can remove the heads and oil pan and see if theres hope for it.
I did get the exhaust manifolds off and was able to look inside the openings there. The cobwebs didn't make me feel any better.
Estimated the weight of the manifolds at about 40 lbs....boy was I wrong....LOL
