Can a bad fule pump make the same noise as a loose valve on a Yamaha 4 stroke?
Timmstng67
Hi
I have a 2004 F75 4 stroke that is making a tapping sound above 3500 rpm at about the same place the fuel pump is located on the valve cover it sounds just like a loose valve tapping the engine was running quite and all of the sudden it has this noise. Any Help would be appreciated
Thanks Tim
CatTwentyTwo
Re: Can a bad fule pump make the same noise as a loose valve on a Yamaha 4 stroke?
The fuel pump can make a tapping noise if it is starving for fuel. You might want to check the filter or fuel line for restrictions or an air leak.
rodbolt
ill second what ryoung says.
thebeav
Yes
