Re: Fold Away Hinges
IMO, if it means the difference between getting the boat in your garage or not, then they are a very good option. They are not very costly and should work well. As tashasdaddy said the weight capacity specs are clearly spelled out and if I remember right are good up to a 5000 pound load. You should be fine. They do require welding though.
I actually almost put one on my previous boat, but then moved to a new house and had a 40' x 54' pole barn built and have no need for it anymore.
