motorguide problem
astroglass
My 46lb Motorguide trolling motor is cutting out after about 5 minutes of continual use,I fish a lake where there is a 10 hp restriction so I have to use my trolling motor to travel about 15 minutes to fish, works fine when Iam beating the banks (on & off)
Silvertip
Re: motorguide problem
The circuit breaker at the battery is tripping, cooling, resetting, tripping, etc. You either have poor connections, corroded connections, wire gauge is too small for the current load, to name just a few problems.
astroglass
Thanks For The Suggestion Silvertip ,i Did Find Where Water Had Got Into The Connection In The Front Where The Trolling Motor Plugs In,i Cleaned It Out And Will Try It To See If That Was The Problem ,i Will Let You Know ,thanks
