Chaparralbob
Thread starter- Joined
- Jun 30, 2009
- 64
Yet another fuel problem, but I haven't found the answer to this after considerable research...
My boat sat for 2 years as a result of heart surgery - no surprise, it wouldn't run this summer. I replaced the gas and fuel filters, and disassembled and cleaned the fuel injectors and pressure regulator. The engine now runs, but not well. It will crank occasionally, and then run for a short time. I can see gas squirting from the injectors while it runs, and it stops when I no longer see the gas squirting. It seems as though I am not getting enough fuel to the injectors.
I have run the pump directly into a fuel pressure gauge, and get about 30 lbs of pressure while the pump is running (for the short time the pump runs after turning on the ignition). Unfortunately, none of the local shops have the T fitting needed for the GM TBI - so that is why I have just measured the pressure directly. I hit the little bypass button on the pressure gauge, and it seems to flow clean gas, with no air bubbles, at a reasonably good rate into a little coffee can; again, while the pump is running. The pressure bleeds back down to near zero when the pump stops in several seconds. Several posts said something about checking the gas level in the fuel filter (spin-on filter and water separator), and it was full of gas, almost to the top.
The boat only has about 105 hours on it, and until recently, was well-maintained and trouble free.
Are these normal pressures? Is it normal for the pressure to bleed back down?
I am wondering if I might have done something to the pressure regulator when I put it back together?
I greatly appreciate any help with this - the budget just won't let me take this to the boat shop right now. Also, they are 4 weeks behind right now - it is their peak season!
Thanks!
Thanks!
