warwick09
Thread starter- Joined
- Oct 6, 2007
- 12
Good day all
Havent posted much but spent/spend a great deal reading or observing if you may - learned many things ill add.
Aite - Ill use this thread as both a showcase for others and to inquire as really boat building ain't exactly my thing but as with anything else just gotta suck it up and go at it.
Hopefully manana ill get a chance to add pics as mi laptop hard drive decided it had enough of my abuse - i've only got one before pic.
The floor and everything else is ripped up, removed transom...took out all fittings etc.
Man was it far worse than I expected - to think it all started out with a little flex of the engine on the bracket - stringers COMPLETELY shot.
I've already made necessary preparation for installation of the new transom but just need to know if it's wise practice to install the stringers first? Also how many layers of ply do you think will suffice enough to hang a 200 carbed off the back with 3ft offset? and lastly should I place a layer of biax in between each layer of wood or just the outer skin? (will be using epoxy for transom)
Hope this wasnt too much for one post.
Thanks in advance
Before picture...
Thanks in advance
Before picture...
