Ignorance SUcks! Rotor Button Stuck.
Charlieg
89 bayliner, Alfa 1, 5.7 - I\O,
The rotor button wont come off of the shaft, unless im ignorant, and i probably am, it should lift right off, Right?. i don't want to break anything, but im about to get a hammer and see if i can tap it loose. before i did that i wanted to check if anyone knows more about this, Thank you In advance.
"Happiness without struggle is Impossible"
danond
Re: Ignorance SUcks! Rotor Button Stuck.
Yeah its supposed to lift off. Warm it a bit with a heat gun/hair dryer, maybe?
JustJason
nahh... they are glued on from the factory... that and who knows how much rust is on the distro shaft.
A light hammer and a sharp chisel is all you need.
P 0 P E Y E
Depends on the rotor type. Double check the book.
If engine still runs, run it to warm it up, then give it a try.
Hope you have success
Charlieg
it has the thunderbolt ignition system on it, but the book doesn't go into much detail about it so i figured it should just lift off.
QC
JustJason is correct. Many of these rotors are locktited on . . . I have used a propane torch.
Charlieg
ok, so i cut it off with a chisel, do i need to glue the new one, or just put it on there? the manual is great if you know what you are doing i guess.
Charlieg
torching plastic? wont that make a mess, or are you just warming the button a little. :confused:
QC
I locktited my last one. I don't think Merc would do it because they own stock in Locktite . . .
Mike250
It's glued on.
I had the same problem and used a heat gun as stated above.
JustJason
Some people use heat i guess... i've just chiseled them off. Just go lightly and use a sharp chisel... you don't want to whack the thing so hard that you bend the shaft (be pretty hard to do... but i wouldn't put it past anybody)
And no... you don't have to glue the new one on.
