Chilly Willie
Thread starter- Joined
- Jun 15, 2009
- 4
Hello everyone - my first post after lurking for a long while.
I have a 1990 Johnson 60hp that starts to bog down badly around 1100 rpm and eventually will die out (makes an odd sound like it's missing or sucking air). Any lower rpm and it dies instantly. It runs good at high rpm.
I just ordered a manual for it, but hoping in the meantime I can get some input.
How do you get the carbs (3 of them) off?
- I want to remove the carbs to check them over, but I can't figure out how to get them off. I see the nuts on the mounting studs from the intake manifold, but there isn't enough room to get them off because they butt up against the carb. My next thought then was to remove the entire intake manifold with carbs attached but I can't get on the bottom 2 bolts.
Leaking fuel on primer solenoid tee
- I found that I'm leaking fuel around from what I believe is the primer solenoid tee fitting. The lines on this tee are zip tied but still fit very loosely on the fitting (I can easily pull them off and on) and fuel is obviously leaking. Other lines also have no zip ties/clamps where they meet fittings. Any chance that this leaking is causing my problem (not getting adequate fuel when at lower rpms)?
Thanks!!
Willie
Thanks!!
Willie
