I could do with some advice on how to get my motor warmed up right. Once warm it runs perfectly, and restarts instantly for an hour or so afterwards. But when I first get it into the water it is a real beast to get running. It starts immediately, and will run for about 30 seconds before starting to falter. If I put it into gear, it dies. Normally just after we have cast off, among the moorings. It then will not restart! The same happens if I wip the cover off, and give it some full throttle manually in neutral to blow out some smoke for 30 secs or more. It will then idle ok, but when I put it into gear and try to pull away it dies a few more times.
So far I have been lucky and have got it running just before being in real trouble, and it will falter for a bit as I open the throttle as far as I can in the moorings, but then it will suddenly clear and run smooth. At which point I can idle again no problem and she runs like a dream!
How can I fix this? Or at least get the engine warmed up prior to launch? I am beach launching which means I quite often don't have the depth to start her up whilst tied up.
Any tips appreciated!
