1977 Mercury 850 Cooling at high speeds
smara04
At idle and low speeds I have water coming out of the little hole on the side of the motor so it is cooling fine.
When I plane out and start cruising no water at all. Right when i slow down steam starts shooting out of the hole, then in about 10 sec here comes the water again.
I need to know what to look at first before i start tearing into this motor. Please Help Im confused!!!
Laddies
Banned
Re: 1977 Mercury 850 Cooling at high speeds
Either the plastic pickup plates are distorted or the most likely thing is there is junk (impeller pieces) inside the cover plates or a exhaust leak on the pickup side of the pump, bad gasket or crack in the pick up or lower pump housing.
smara04
replaced impeller cools like a champ now Thanks!!
