Hey
I am in the process or have been in the process of fixing up the scrapes, chips etc from the bottom of my 15ft fibreglass runabout which I have recently purchased. The keel was worn back and chipped from continuous beaching or possibly even from hitting trailer.
Anyhow I have gone around numerous spots on the boat and repaired using brush on gelcoat. I have found however it is near on impossible to get a close color match to the hull. Everytime I sand back the gelcoat which has been brushed on the immediate area surrounding the repair spot also changes color due to sanding back of the old original gelcoat. Also the gelcoat is quite thin and seeing as I have already had to sand back the previous owners gelcoat repair paste (colored yellow - hull is white / grey) this has left me with areas where sanding has braught me back to the glass.
You can see in the photos some examples of some of the areas on the hull which have been fixed. Is it worth continuing to brush gelcoat on and attempt to do a touch up which is not noticeable or should I bite the bullet now and paint the entire hull????? Sanding back the brush on gelcoat is getting too hard the stuff dries so hard..... it takes forever
I was thinking of Internation Brightside which I can roll and tip. Boat is trailered so wont ever be in water for long periods of time.
Any opinions would be much appreciated!
Cheers
Cheers
