FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
I have a 1961 Johnson and need to split the lower end so that I can replace the shift rod bushing. The threaded rod nuts came right off, what are the tricks to split the lower end to access the bushing?
What engine/model hp is it? The skeg just unscrews off. 6 screws. Then pry apart gently with a screwdriver... Then the prop shaft comes out easily... slight gentle prying required then the shift rod slides right out. To remove the bushing with the shifter O ring search on this forum and you will see the simple tool to buy or make to pop it out.
